Error saving new extension
Discussion in '3CX Phone System - General' started by kdubious, Mar 7, 2011.
  1. kdubious
    Jan 17, 2009
    9
    3CX Interface
    An exception occurred EditExtension Error: Index was out of range. Must be non-negative and less than the size of the collection.
    Parameter name: index
    OK
    I'm on SP Version 5a. (9.15781) Trying to add an EMail Address triggers it, along with other changes.
    Kevin
  2. abc123
    abc123 Active Member
    Nov 9, 2009
    712
    What number did you give the extension?
  3. kdubious
    Jan 17, 2009
    9
    206. It is unique.
  4. abc123
    Nov 9, 2009
    712
    Is it just this extension or can you not add any extension?
    It seems 3cx has got confused somewhere. Maybe a pc reboot would fix it.
  5. sigma1
    sigma1 Active Member
    Nov 20, 2009
    542
    First - Are you using a 3-digit system? you cannot mix and match (i.e. select 2 or 4 or 5 digits) and then pick whetevr unused number.
    Second - try creating another extension and see if it happens again
    If in doubt, open the system extension tab and you will see what the system extensions are (2-3-4-5 digits).
  6. Pgeo
    Dec 6, 2011
    Hi!
    I have the same problem...
    When i Create and save an extension, the system pops up an error msg.
    If i update an extension the same happens, but almost everything is updated.
    Extension numbers are 2 digit. It creates the new extension besides the error msg.
    I have an extension number 10. The Disallow use of extension outside the LAN option is enabled, and cannot disable because of this message. Current status, Turn off myphone can be set and saved, but error always there.
    Using v10.0.22052.2264 SP.4 management console
    Thx for the answer
  7. Pgeo
    Dec 6, 2011
    Still having the problem.
    I deleted all extension, when i create a new, i'm always having the error.
    Do i really have to re-install the whole system?
    This is the ONLY solution?
    Lol, i like this prog, but cannot believe, that no one can answer this question.
  8. Pgeo
    Dec 6, 2011
    Reinstall did it.
    Little disappointed...
