error.semantic.ecmascript
Discussion in 'CRM / Helpdesk / App Integration' started by SWSDEV, Oct 1, 2009.
  1. SWSDEV
    SWSDEV Member
    Feb 23, 2008
    256
    On the error.semantic.ecmascript error, it would be helpful if we knew which string value it was having a problem with.
  2. zensoftware
    zensoftware New Member
    Aug 23, 2007
    225
    Same here, its showing this error in connection with writing to SQL but i have no idea if which string it is or even if it can connect to the SQL server at all.
    Emmet.
  3. VAD_Support
    VAD_Support Active Member
    Aug 6, 2009
    690
    That information can be found in the 3CXIvrServer.log file.
    Can you check it out?
