Error time exceeded
Discussion in '3CX Phone System - General' started by elistas, Oct 18, 2007.
  1. elistas
    Oct 18, 2007
    9
    I get this ins the footer of the admin Fatal error: Maximum execution time of 65 seconds exceeded in D:\3CX PhoneSystem\Data\Http\status.php on line 376
    What is this. How i SOLve
  2. miraportuga
    miraportuga Member
    Aug 7, 2007
    297
    Have you tried to reinstall already ? if not try that... uninstall current installation, delete all 3CX folders.... then reinstall...
    Cheers
  3. elistas
    Oct 18, 2007
    9
    Look the problem is if i look in one remote computer but i no have this problem in the local host.
    Sure there any variable for configurate Maximum execution
  4. miraportuga
    miraportuga Member
    Aug 7, 2007
    297
    I still say that something must be wrong with the 3CX instalation, thats why i said reinstall, that, or some conflict with some other thing installed on the same computer... or... Firewall. there are several possibilities.... so my advise would be start be trying solutions, one by one to see what the problem really is....
    Cheers
