Error Transfering Calls !!!
Discussion in '3CX Phone System - General' started by mazizeh, Jan 18, 2008.
  1. mazizeh
    Jan 18, 2008
    I installed the free version on 3CX 5 (latest). I configured everything correctly (extensions, SIP trunks, IVR, etc).
    Whenever I call my DID number (which initiates the main IVR), the IVR will try to connect me to an extension (sales=1, techsupport=2).
    BUT I only hear the prompt "trying to connect to the extension" then the prompt "sorry, the transfer failed".
    I have the old verison 3.0, I tried it and transfer works great.
    What is the problem in version 5? Can you help in fixing this issue please?
  2. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    Remove tick from "Support re-INVITE" option on provider configuration page.
    You may post copy of log from "Server Status" page here. It will provide more information about problem.
  3. mazizeh
    Jan 18, 2008
    1- Support Re-Invite is not ticked.
    2- Log:
    18:47:47.653 LineCfg::getInboundTarget [CM503011]: Inbound out-of-office hours' rule for LN:10000 forwards to DN:8000
    18:47:43.232 Call::RouteFailed [CM503014]: Call(4): Attempt to reach [sip:5010@127.0.0.1] failed. Reason: Not Registered
    18:47:43.232 CallCtrl::eek:nSelectRouteReq [CM503015]: Call(4): Target is not registered: Ext:Ext.5010
    18:47:34.966 LineCfg::getInboundTarget [CM503011]: Inbound out-of-office hours' rule for LN:10000 forwards to DN:8000
    As logs says: failed. Reason: Not Registered
    When the device (extension) is not registered ... the transfer faild.
    I tried all the options in Destination Unreachable / Forwarding >>> when the device is not registered BUT still transfer failed!!!!!!
    Please help
