Error trying to add Extensions
Discussion in '3CX Phone System - General' started by nahidul, May 15, 2008.
  1. nahidul
    Jul 9, 2007
    28
    Hello.
    Getting error when trying to add extensions. Please help.
    "3CX Phone System internal error.
    Object duplication error
    Cannot save User object: ERROR: duplicate key violates unique constraint "users_pkey"<br>#0 C:\Program Files\3CX PhoneSystem\Data\Http\functions\fUser.php(56): safeExec(Object(PDOStatement), 'Cannot save Use...')<br />
    #1 C:\Program Files\3CX PhoneSystem\Data\Http\user_extension_info.php(1046): fUser::save(Object(oUser))<br />
    #2 C:\Program Files\3CX PhoneSystem\Data\Http\functions\gui\fmPage.php(70): aOnOk->execute()<br />
    #3 C:\Program Files\3CX PhoneSystem\Data\Http\functions\gui\fmPage.php(85): fmPage->processData()<br />
    #4 C:\Program Files\3CX PhoneSystem\Data\Http\functions\gui\fmPageEx.php(110): fmPage->toHTML()<br />
    #5 C:\Program Files\3CX PhoneSystem\Data\Http\user_extension_info.php(1096): fmCustomPage->toHTML()<br />
    #6 {main}"
    With Thanks
    Nahid HOSSAIN
  2. scdebaay
    May 16, 2008
    This looks like a DB error. Would this be concerning an extension you once made, deleted and now are trying to make again?
    It seems that the deletion process writing to the database did not go as planned and that there is a record in the DB with a unique key identifier which needs to be deleted before the new extension can be remade. As the database is, I believe, a postgre SQL database, you will need a tool to access and edit the db directly.
    On the other hand I would not recommend this, and see whether the 3CX staff can shed a light on this.
  3. demonofsteel
    demonofsteel New Member
    Mar 28, 2008
    105
    If you can't find a solution to correct this, I would recommend you to uninstall 3CX first, then remove any version of software you could use to admin a postgre SQL DB and also remove any Apache server. Then reinstall...
    Weird DB errors often occur if you alrady have a DB manager on the server you installed 3CX on.
