Error updating 3CX client
Discussion in '3CX Clients' started by IBML, Jan 9, 2018.
  1. IBML
    Nov 17, 2017
    8
    I have an issue, every time we update the 3CX client
    The Clientstart, notifies the user of the update, once you click OK to update we will get the error seen on the attached picture.
    this persists since the last 3-4 client updates
    On the local network
    tried to unload / uninstall Antivirus = no success
    tried disable firewall = no success
  2. Nicolas Jene
    Feb 8, 2018
    I have the same issue. It worked once, but it stopped.
    I tried to disable as well Antivirus and firewall and excluded as well the 3CX client folder from scanning.
    Any suggestions from anyone?
    Greets -Nicolas
  3. IBML
    Nov 17, 2017
    8
    No change on the 15.5 SP3 update
    3CX clients still fail to update with the same error.....
    This worked one time after we installed 3CX in autum 2017, since then -> failing
  4. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    6,016
    421
    Hello @IBML
    What happens when you un-install a client and re-install the new version? Does that work or do you still get an error?
    Please make sure that windows are fully up to date and that C++ redistributables are installed for both x86 and x64.
  5. IBML
    Nov 17, 2017
    8
    Well i havn't tried to uninstall and reinstall the client, but this does not help now, since i need to wait for the next update.... i'm on the latest version.
    This happens on Windows 7 to Windows 10 1709, all fully patched (Feb 2018)
    C++ redistributables are installed (see attached)
    Where can i download an older version of 3CX client for Windows ?
    The verson before 15.5.8801.3
  6. Nicolas Jene
    Feb 8, 2018
    I downloaded the client manually from the website and installed it. This worked. But after a new update, I still get the error.
    So the whole update mechanism seems not to work anymore. I have exactly the same: Worked once we installed 3CX in 2017 and after while -> no updates anymore ...
  7. YiannisH_3CX
    May 10, 2016
    6,016
    421
    How did you get to the latest version? Did the update work?
  8. YiannisH_3CX
    May 10, 2016
    6,016
    421
    Do you currently have a client that does not update so we can take a look?
  9. Nicolas Jene
    Feb 8, 2018
    No, I just updated my client manually. One of my employees was 3 month away and we tested it. He did not get an update notice and the client was not able to connect properly. So we had to install as well a new client manually.
  10. cscforce
    Nov 6, 2015
    I have the same problem across a dozen clients. I have tried messing with TLS settings in the nginx config, disabling anti virus, to no avail. Not sure what the issue is here. It has been like this since updating to 15.5 (I think). See photo.
  11. cscforce
    Nov 6, 2015
    I have verified C++ 2015 x86 and x64 was installed, then I installed 2017 x86 and x64 to make sure that wasn't the issue with no success.
  12. LeonidasG
    LeonidasG Support Team
    Nov 19, 2008
    1,473
    94
    This is unrelated to pre-requisites.
    Please list the following:
    • 3CX PBX Version
    • Current 3CX Client for Windows Version
    • Target 3CX Client for Windows Version (The version of the one you're trying to update to)
    • Go to %programdata%\3CXPhone for Windows\PhoneApp and let me know whether you have a file called "TcxPhoneUpdater.exe" and a file called "tmpTcxPhoneUpdater.exe"
    • Also let me know of the version of the "TcxPhoneUpdater.exe" and the "tmpTcxPhoneUpdater.exe" files by right clicking them and then selecting properties to see the version.
  13. IBML
    Nov 17, 2017
    8
    happened from pre (no idea what the number was) 15.5.9348.3 version and the corrosponding 3CX Client for Windows
    I bet i have the same isseu on the SP4 update
    Happens on fully patched Windows 7 64 bit and on Windows 1703 1709 fully patched
    tmpTcxPhoneUpdater.exe version see attachment
    To make it clear this happen since version 15 !
    Nathan Boyd likes this.
  14. LeonidasG
    Nov 19, 2008
    1,473
    94
    Thanks.
    We've found what could be a minor bug in the updater which is also why this isn't something many users experience. We'll let you know once we have more on this.
  15. IBML
    Nov 17, 2017
    8
    Leonidas,
    great news ! thank you and keep us posted
  16. Nathan Boyd
    Feb 2, 2017
    46
    10
    I'd like to echo this. I've noticed it at multiple clients now since V15. Glad to see that 3CX is working on the issue.
  17. LeonidasG
    Nov 19, 2008
    1,473
    94
    This is related to custom PBX configs on nginx where you've likely manually disallowed TLS 1.0 and only allow TLS 1.2 probably because of some need to be PCI compliant or as extra security.
    Due to this custom nginx config by the user himself, the 3CX Client doesn't like it and throws this exception.
    Without going into much detail on this, a fix/improvement on this will be available in SP5. If you cannot wait till then, PM me for a new 3CX Client Version. You will have to install/update to this version manually.
    IBML and Marios Neophytou like this.
  18. IBML
    Nov 17, 2017
    8
    Leonidas,
    thank you for the update.
    I would not call this a custom config on ngnix, TLS 1.0-1.1 are dangerous weak and have to be turm off. so this is a mandetory change.
  19. LeonidasG
    Nov 19, 2008
    1,473
    94
    Of course, i agree with the security aspect of this.
    It still is custom config made by the user, this is a fact.
    Regardless, you will be seeing something about this in SP5.
    craigreilly likes this.
  20. LeonidasG
    Nov 19, 2008
    1,473
    94
    A new version of the 3CX Client for Windows is available in your PBX's management console that fixes this issue.
    To deploy this you will unfortunately need to revert your Nginx to 1.0 TLS, have everyone update their clients and then switch Nginx back to 1.2 TLS.
    If you don't want to do this you will have to download the .msi file from the link below and manually update all 3CX Clients. After this, the exception you're getting should never occur again.
    https://www.3cx.com/phone-system/3cxphone/
