Solved Error Updating 3CX from version 15.5.6354.2 to 15.5.8801.3
Discussion in '3CX Phone System - General' started by a9, Mar 14, 2018.
  1. a9
    a9
    Nov 30, 2011
    Hi everyone,
    one of our PBX's are having an issue updating to the latest version
    Update.log:
    Reading package lists...
    Building dependency tree...
    Reading state information...
    Some packages could not be installed. This may mean that you have
    requested an impossible situation or if you are using the unstable
    distribution that some required packages have not yet been created
    or been moved out of Incoming.
    The following information may help to resolve the situation:
    The following packages have unmet dependencies:
    3cxpbx : Depends: postgresql (>= 9.6) but it is not going to be installed
    Depends: libssl1.0.2 but it is not installable
    Depends: libicu57 but it is not installable
    Depends: libcurl3 (>= 7.52.1) but it is not going to be installed
    Conflicts: libssl1.0.0 but 1.0.1t-1+deb8u7 is to be installed
    E: Unable to correct problems, you have held broken packages.
    Rollback to 15.5.6354.2...
    3cxpbx is already the newest version.
    0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
    if Anybody has an suggestion it would be greatly appreciated
    Best Regards,
    Gerard Delaney
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    4,967
    324
    a9 likes this.
  3. a9
    a9
    Nov 30, 2011
    Tanks so much that worked
  4. YiannisH_3CX
    May 10, 2016
    4,967
    324
    Glad i could help
