Error using OMsamples
Discussion in 'CRM / Helpdesk / App Integration' started by Apereira, Aug 1, 2016.
  1. Apereira
    Jul 23, 2016
    12
    Trying to get 3CX to report us live information about what is happening on our customers 3CX.
    So I've installed 3cx v15 on my machine(windows 10 64bit) so I can do some tests.
    When running OMSamples, I get the error.
    In fact, according to the documentation, this key is present in the dictionary.
    Can someone please help?
  2. Apereira
    Jul 23, 2016
    12
    Adding more information.
    Tried to replicate the code from "Add extension", and got the following error.
    On line
    Code:
    PhoneSystem ps = PhoneSystem.Root;
  3. edossantos
    edossantos Support Team
    Jun 27, 2007
    1,078
    76
    The exception BadImageFormatException looks like a bitness mismatch. That means, your app is x86 and tries to load an x64 assembly. Check if your application is x86, in that case change it to AnyCPU or x64.
  4. Apereira
    Jul 23, 2016
    12
    Thanks for your reply,
    I've tried this and when I try to remove an extension I don't get output.
    although this looks like it still not working.
    I've created a test extension number 501
    command I am trying to run
    Code:
    OMSamples.exe remove_extension 501
    On the other way, when trying to use my app.
    Now I get
  5. edossantos
    Jun 27, 2007
    1,078
    76
    That DLL is in folder "C:\Program Files\3CX Phone System\Bin". Copy it to your project output folder.
  6. Apereira
    Jul 23, 2016
    12
    Tried that before with no luck.
    On my output folder, I have,
    3CXPhoneSystem.ini
    tcxpscom_native.dll
    And I've added a reference for 3cxpscomcpp2 that is located on "C:\Program Files\3CX Phone System\Bin"
    Do I need to move also this file to my output folder and add it as a reference from there?
  7. edossantos
    Jun 27, 2007
    1,078
    76
    In your reference set CopyLocal to true, and that will copy the DLL to your output folder.
  8. Apereira
    Jul 23, 2016
    12
    It was already set to true.
    That's weird, looks like it is trying to get the file from a different path.
    Error:
  9. edossantos
    Jun 27, 2007
    1,078
    76
    Check if your program is executing with the current directory set to the exe location. Sometimes it runs for example in C:\windwos\system32. Try debugging the app and check the value of "System.IO.Directory.GetCurrentDirectory()" or "Application.StartupPath".
  10. Apereira
    Jul 23, 2016
    12
    yes, it is running on the Debug folder where the files are located.
    The issue is that the documentation is not that clear about what to do.
    Tried also to add the DLL's to the project and still with the same output.
  11. Apereira
    Jul 23, 2016
    12
    After a few attempts still having the same issue, it states that it can't load the other DLL.
  12. edossantos
    Jun 27, 2007
    1,078
    76
    Did you also copy the sl.dll library? Just in case copy all the dlls from 3cx installation to your app folder, because maybe the problem is not the mentioned dll but a dependency.
  13. Apereira
    Jul 23, 2016
    12
    Great! Looks like it worked cause is not returning me any error now.
    Although this, it is not returning me any information from the 3Cx installation
    I've used the code from the example to try to list all the extensions and some other information as an example.
    But it is not returning them.
    Code:
    using System;
    using System.Collections.Generic;
    using System.Linq;
    using System.Text;
    using System.Threading.Tasks;
    using TCX.Configuration;
    using System.Threading;
    namespace _3CXV15
        class Program
            static void Main(string[] args)
                Console.BackgroundColor = ConsoleColor.DarkBlue;
                try
                    Console.WriteLine("Extensions");
                    System.Console.WriteLine("Parameters:");
                    foreach (Parameter p in ps.GetParameters())
                        System.Console.WriteLine("\t" + p.ToString());
                    System.Console.WriteLine("Codecs:");
                    foreach (Codec c in ps.GetCodecs())
                        System.Console.WriteLine("\t" + c.ToString());
                    System.Console.WriteLine("Conditions:");
                    foreach (RuleCondition rc in ps.GetRuleConditions())
                        System.Console.WriteLine("\t" + rc.ToString());
                    System.Console.WriteLine("RuleHours:");
                    foreach (RuleHours rh in ps.GetRuleHourTypes())
                        System.Console.WriteLine("\t" + rh.ToString());
                    System.Console.WriteLine("RuleCalltype:");
                    foreach (RuleCallType rct in ps.GetRuleCallTypes())
                        System.Console.WriteLine("\t" + rct.ToString());
                    foreach (Tenant t in ps.GetTenants())
                        System.Console.WriteLine(t.ToString());
                        System.Console.WriteLine("\tOfficeHours:");
                        foreach (HoursRange hr in t.OfficeHoursRanges)
                            System.Console.WriteLine("\t\t" + hr);
                        System.Console.WriteLine("\tExtensions:");
                        foreach (Extension e in t.GetExtensions())
                            System.Console.WriteLine("\t\t" + e);
                            System.Console.WriteLine("\t\t\tProperties:");
                            foreach (DNProperty d in e.GetProperties())
                                System.Console.WriteLine("\t\t\t\t" + d);
                            System.Console.WriteLine("\t\t\tForwarding:");
                            foreach (ExtensionRule er in e.ForwardingRules)
                                System.Console.WriteLine("\t\t\t\t" + er);
                        foreach (IVR ivr in t.GetIVRs())
                            System.Console.WriteLine("\t\t" + ivr.Name);
                            System.Console.WriteLine("\t\t\t" + ivr.Number);
                            System.Console.WriteLine("\t\t\t" + ivr.PromptFilename);
                            System.Console.WriteLine("\t\t\t" + ivr.Timeout);
                            System.Console.WriteLine("\t\t\t" + ivr.TimeoutForwardType.ToString());
                            DN dn = ivr.TimeoutForwardDN;
                            if (dn != null)
                                System.Console.WriteLine("\t\t\t" + dn.ToString());
                            else
                                System.Console.WriteLine("\t\t\t" + "not specified");
                catch (Exception e)
                    Console.ForegroundColor = ConsoleColor.Red;
                    Console.Write("ERROR: ");
                    Console.ForegroundColor = ConsoleColor.White;
                    Console.Write(e.ToString());
                Console.Write("Press enter to finish!");
                Console.ReadLine();
    What am I doing wrong here?
  14. edossantos
    Jun 27, 2007
    1,078
    76
    You might need to wait until PhoneSystem.Root.Connected returns true, so you're sure it's connected to the Phone System.
  15. Apereira
    Jul 23, 2016
    12
    thanks for your reply.
    Do you mean that I need to first have a function to connect to the phone system?
  16. edossantos
    Jun 27, 2007
    1,078
    76
    Yes, you usually want to do something like this to wait up to 1 minute for the connection:
    Code:
            bool configSrvConn = false;
            int checkCount = 0;
            do
              try
                configSrvConn = PhoneSystem.Root.Connected;
              catch (Exception exc)
                Log.Info("Configuration server not connected. Waiting 10 seconds to retry: " + exc.Message);
                Thread.Sleep(10000);
                checkCount++;
            } while (!configSrvConn && checkCount < 6);
  17. Apereira
    Jul 23, 2016
    12
    Code:
    returns me the value True, so I assume it is connected.
    Although this it is not returning any value.
    (sorry for been so difficult)
  18. edossantos
    Jun 27, 2007
    1,078
    76
    Are you setting the ApplicationName property? It's very important, otherwise the server will reject the connection. You need to set it to a unique name, as follows:
    Code:
                    var a = new Random(Environment.TickCount);
                    PhoneSystem.ApplicationName = "TestApi" + a.Next().ToString();
  19. Apereira
    Jul 23, 2016
    12
    Still not retrieving any info.
    Code I have on this function.
    Code:
            static void DisplayAllInfo()
                int checkCount = 0;
                Console.WriteLine(PhoneSystem.ApplicationName);
                do
                    try
                        Console.WriteLine("Configuration server not connected. Waiting 10 seconds to retry: " + exc.Message);
                        checkCount++;
                Console.WriteLine("Connected to PBX: " + configSrvConn.ToString());
                try
                            if (dn != null)
                            else
                catch (Exception e)
                Console.Write("Press enter to Continue!");
                Console.ReadLine();
  20. edossantos
    Jun 27, 2007
    1,078
    76
    Hi there,
    We've published an updated samples package for v15 which works fine. Please download it again and give it a try.
    Kind regards.
