Error when backupping
Discussion in '3CX Phone System - General' started by Rob24h, Dec 15, 2017.
  1. Rob24h
    Mar 20, 2017
    69
    5
    I have several V15.5 PBXs that are backupping to a FTP server. All of them work fine except 1 PBX.
    This PBX gives the following error:
    3CX Phone System tried to backup but failed due to the following reason(s):
    System.Exception: Error creating backup ---> System.IO.IOException: Unable to write data to the transport connection: No route to host. ---> System.Net.Sockets.SocketException: No route to host
    at System.Net.Sockets.Socket.Send(Byte[] buffer, Int32 offset, Int32 size, SocketFlags socketFlags)
    at System.Net.Sockets.NetworkStream.Write(Byte[] buffer, Int32 offset, Int32 size)
    --- End of inner exception stack trace ---
    at System.Net.FtpClient.FtpSocketStream.Write(Byte[] buffer, Int32 offset, Int32 count)
    at System.Net.FtpClient.FtpDataStream.Write(Byte[] buffer, Int32 offset, Int32 count)
    at System.IO.Stream.CopyTo(Stream destination, Int32 bufferSize)
    at _3cxNetBackupAndRestore._3cxBackup.FinishingTask()
    at _3cxNetBackupAndRestore._3cxBackup.WaitForFinish()
    at _3cxBackupRestoreImpl.BackupRestoreUtils.Backup(IFilesystem filesystem, String instanceId, String cfgPath, String dbConnectionString, BackupConfig options, String fullpathFilename, Boolean sendEmail)
    at BackupRestoreSchedule.BackupJob.Execute(IJobExecutionContext context)
    All settings are checked and they are exactly the same .
    The size of this backup file is about 300 MB.
    How to fix this backup?
  2. Rob24h
    Mar 20, 2017
    69
    5
    Is someone from 3CX reading this and can they advise on how to patch this?
  3. Rob24h
    Mar 20, 2017
    69
    5
    Restarting all the services didn't help.
    Manually running a backup still works but the sheduled backup does not work.
    @3cx please comment on this.
  4. nb
    nb Support Team
    Jun 7, 2007
    2,123
    150
    No route to host. A networking problem.
    Your pbx has a dynamic ip? Is the ip changing (public ip)? or is it always the same?
  5. Rob24h
    Mar 20, 2017
    69
    5
    I have several 3CX PBXs, all hosted in the same datacenter and they all have a static IP. The back-up process works on all PBXs except this one. When I manually back-up it always works.
    I have a constant ping to both the FTP backup server and the PBX. No packets are lost on both of them.
  6. nb
    nb Support Team
    Jun 7, 2007
    2,123
    150
  7. Rob24h
    Mar 20, 2017
    69
    5
    Already tried this but no luck.
    I will try this today!
