- Joined
- Jul 6, 2010
- Messages
- 49
- Reaction score
- 0
I am new to 3CX so this could be something easy I overlooked.
I installed and configured 3CX last year along with a VAD project to verify callers pin codes and then forward based on the input being valid/invalid. Unfortunately right before putting this in production the whole project was stopped and 3CX was put on hold until recently.
I have installed 3CX v9 on a new server and imported the backup from previously and finished the configuration. Everything is working great except the VAD project. It hangs up instantly with no error that I can see.
I looked through the project again and did not see anything problematic and the same project worked perfectly before. To test I removed the digital receptionist and then tried to build and deploy the project again to see if it was just an issue of it being applied from a backup.
Unfortunately when trying to deploy I receive the error:
"object reference not set to an instance of an object"
I am trying to deploy this as a release build and I see it start uploading one WAV file and then the error is seen.
I cant find any logs that points to anything helpful.
Any ideas out there? I am praying I don't have to build it from scratch because it took me 3 weeks the last time to create this and get it working.
Thanks,
Chris
Thanks,
Chris
