Error while compiling CFD Example
Discussion in 'Call Flow Designer' started by igor.snezhko, Feb 1, 2018.
  1. igor.snezhko
    igor.snezhko Active Member
    Jan 7, 2008
    667
    7
    Hi!
    Our customer tries to compile app from this manual https://www.3cx.com/docs/cfd-creating-phone-support-portal-1/ but receives errors below. Can you advise, please?
    Compiling the created source code to .NET library…
    Error compiling source code to .NET library: (55,84): error CS1056: Unexpected character ‘$’
    Error compiling source code to .NET library: (55,86): error CS1003: Syntax error, ‘,’ expected
    Error compiling source code to .NET library: (91,98): error CS1056: Unexpected character ‘$’
    Error compiling source code to .NET library: (91,100): error CS1003: Syntax error, ‘,’ expected
    Error compiling source code to .NET library: (55,76): error CS0103: The name ‘callflow’ does not exist in the current context
    Error compiling source code to .NET library: (55,86): error CS0103: The name ‘SalesTeamExtension’ does not exist in the current context
    Error compiling source code to .NET library: (91,90): error CS0103: The name ‘callflow’ does not exist in the current context
    Error compiling source code to .NET library: (91,100): error CS0103: The name ‘SalesTeamExtension’ does not exist in the current context
  2. edossantos
    edossantos Support Team
    Jun 27, 2007
    1,361
    109
    Hi Igor,
    This is pretty sure a missing quote when using strings. Can you show us how you're configuring some expressions?
    Kind regards.
