Error while deploying.
Discussion in 'CRM / Helpdesk / App Integration' started by 5loth, Aug 6, 2009.
  1. 5loth
    Aug 6, 2009
    We are getting the following error message when trying to deploy to our test server for debugging:
    And error occurred while deploying this project.
    config server is not connected.
    The upload bar gets about half way across to:
    Uploading file "Root_new_new.vxml"
    I have restarted server and services.
    Removed firewalls as its in a test environment.
    Kind Regards,
  2. elantech
    Jan 23, 2008
    20
    Iam also meet this error, but after restarting all work OK.
  3. 5loth
    Aug 6, 2009
    I tried restarting the server.
    Will have another go, suppose it can't make it any worse.
  4. 5loth
    Aug 6, 2009
    Rebooted PC, Server and everything else I can think of...
    Still same problem :(
  5. 5loth
    Aug 6, 2009
    I installed the program on the server as well.
    Get another error now:
    An error occurred while deploying the project.
    "IVR"
  6. VAD_Support
    VAD_Support Active Member
    Aug 6, 2009
    690
    What version of 3CX are you using?
    The VAD only works with V7.1 right now. V8 support will be added soon.
