Error while sending the message
Discussion in '3CX Phone System - General' started by swapnil, Aug 23, 2007.
  1. swapnil
    Aug 23, 2007
    5
    I am trying to send the message to the address extension_no.@IP_address:5060 but after pressing the send button getting the message that "method not allowed" what's going wrong
  2. gbarnes
    Aug 3, 2007
    83
    ext no
    If you are using sip device or soft phone, that is correctly registered with 3cx (green icon) just dial the extension number and press send.
    Does this work?
  3. swapnil
    Aug 23, 2007
    5
    it's not working
  4. swapnil
    Aug 23, 2007
    5
    Re: ext no
    it's not working.
  5. gbarnes
    Aug 3, 2007
    83
    Not working still.
    Could you cut and paste your log and Ill try to see where its failing.
    If you have two extensions set up and registered, you should be able to enter the other extension number in the phone device and press send or enter to call the other extension.
    Do you have all your extensions under the status panel with green icons, ie all correctly registered?
  6. swapnil
    Aug 23, 2007
    5
    Re: Not working still.
    yes all are correctly registered.call flow is working fine but i am unable to send the message.
