Error with install of new ver...
Discussion in '3CX Phone System - General' started by hagesol, Apr 12, 2008.
  1. hagesol
    Mar 26, 2007
    22
    hi,,,
    I download the new ver. of 3cx, but I got a errormessage: The message say the 3cx-installer could not start a requried program to compleate the installation.
    In the earlier ver. I got the same error, but when I let the 3cx got admin-rights - all where ok. For the new ver, I don't have this options.
    I run Vista premium...
    Any sollutions out there?
    I will be happe if it is... :)
    Lars
  2. BJReplay
    BJReplay New Member
    Oct 31, 2007
    133
    Because this is an msi, you can't run as administrator - but what you can do is run a command prompt as administrator, CD to the directory where the MSI is, and then just type the name at the command prompt. This will install as administrator, and should work.
    This problem was also encounted with V3 MSI installs under vista
  3. hagesol
    Mar 26, 2007
    22
    Hi,,,
    Thanks for your answare,,,
    I tried to do as you tell,
    and now I have installed the 3cx...
    Lars
