Error writing to file: 3cxpscomcpp2.dll
Discussion in '3CX Phone System - General' started by jmatson, Feb 5, 2010.
  1. jmatson
    jmatson New Member
    Nov 30, 2009
    122
    Trying to install 3cx back onto my server. I had prev version running great. Decided to update today and well nothing but problems. i was able to get everything off and now when i am trying to install i get this error msg
  2. mylove4life
    mylove4life New Member
    Jan 7, 2010
    165
    You logged in as Admin?
  3. jmatson
    jmatson New Member
    Nov 30, 2009
    122
  4. nb
    nb Support Team
    Jun 7, 2007
    2,147
    173
    It seems that the previous un-installation did not go so well
    Error writing to file: 3cxpscomcpp2.dll shows that that assembly is already there.
    Follow this guide to remove every trace of 3CX from the machine. http://wiki.3cx.com/documentation/general/installation-checker
    Then try and install 3CX Again.
    What is the operating system?
