Errors on incoming T.38 fax
Discussion in '3CX Phone System - General' started by eagle2, Jul 26, 2011.
  1. eagle2
    eagle2 Well-Known Member
    Apr 27, 2011
    1,085
    11
    I have an issue with incoming T.38 faxes -- parts of the page missing (several strips of about 2-3 cm / 1" in height not present, so the received page is concatenated to the half of its original height). I've checked the ECM and assured it is on.
    Most probably this is a provider problem, nevertheless there is no clue -- NO fax error indicated.
    Any ideas / somebody met similar problem ?
    Regards,
    Orlin.
  2. eagle2
    Apr 27, 2011
    1,085
    11
    This proves to be provider problem (remote party) -- lack of synchronization (ISDN).
    However the interesting point is no error indication.
    Regards
