EULA forbids corp usage?
Discussion in 'Windows' started by ricdanger, May 7, 2012.
  1. ricdanger
    May 7, 2012
    Hi there,
    I downloaded 3CX free SIP phone, and by carefully reading the EULA I figured out that it is only licensed for personal use, and only allows a single copy to be deployed.
    Is this a misswording, missundertanting, or it it really not possible to deploy 3CX free softphone to my company computers?
    Thanks.
  2. efounco
    efounco New Member
    Sep 28, 2011
    148
    I'm pretty sure they want you to purchase it for business use.
    For testing and/or personal use, I'm sure it's OK to use...
  3. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,587
    309
    So does that mean if you buy a licensed version of 3cx Phone System that you have the rights to deploy 3cx Phone to all workstations?
  4. leejor
    11,293
    361
    It may be that the wording is required to protect 3CX from those that may try to re-brand, and. or, sell the softphone. I had not seen a question about this arise previously. The definitive answer would have to come from someone at 3CX (a lawyer? :) ) rather than just speculating.
