Solved Even better User Experience with the latest 3CX Client for iOS
Discussion in 'iOS' started by LeonidasG, Jul 26, 2017.
  1. LeonidasG
    LeonidasG Support Team
    Nov 19, 2008
    1,455
    92
    jed likes this.
  2. Stephen Lilly
    Sep 24, 2017
    It seems the iOS version does not work with ios11 ?
    Is there a fix or are you discontinuing this product ?
  3. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,476
    67
    We have no complaints so far about our client running on iOS 11. Can you provide us some extra information?
  4. Stephen Lilly
    Sep 24, 2017
    Hello
    Thank you for your reply, please see attached screen shot i am seeing
    Kind Regards
    Stephen
      File size:
      102.6 KB
      12
  5. Vali_3CX
    Dec 12, 2008
    1,476
    67
    Hi Stephen
    Wow, I didn't expect that! Now I understand, you have a very old version of our client (I'm assuming it's our first, generic SIP client) which we no longer develop/support it since long time ago and indeed should not be compatible with iOS 11. What version is?
    vali
  6. Stephen Lilly
    Sep 24, 2017
    Im unsure of its version, as i'm unable to get passed this screen - its been installed for many many years and has worked flawless..
    I do have 1.1.5 installed on a old phone
    Is there something else i should now consider ?
    Kind Regards
    Stepehn
  7. Vali_3CX
    Dec 12, 2008
    1,476
    67
    Stephen, unfortunately - no. Basically, we discontinued that version about four years ago. At that time, there were only 32-bit builds, but now, starting with iOS 11, Apple no longer allow them, it requires 64-bit only, that's why iOS display that message box you saw. Strictly speaking, since we no longer develop it, the only solution to use it is to run it on an IOS < 11, there is no other way.
    Sorry for inconvenience
    vali
    P.S I'm assuming you used it as a generic SIP phone, connected to a VoIP provider or a different PBX than 3CX Phone System. In case you use a 3CX Phone System, obviously I highly recommend you to use the latest, 3CX-compatible only client, version
    https://itunes.apple.com/us/app/3cx/id992045982?mt=8
    #7 Vali_3CX, Sep 30, 2017
