Event Log tweaks
Discussion in 'Ideas' started by craigreilly, Feb 17, 2017.
Event Log tweaks 5 5 2votes
5/5, 2 votes
  1. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,575
    305
    1)
    Code:
    SIP Server/Call Manager ID: 12294
    Call or Registration to 1763???????@(Ln.10002@Flowroute) has failed. 216.115.69.144 replied: 404 Not Found; from IP:216.115.69.144:5060
    Perhaps this can say which extension tried to make the call?
    Code:
    Call or Registration to 1763???????@(Ln.10002@Flowroute) has failed from Ext:232. 216.115.69.144 replied: 404 Not Found; from IP:216.115.69.144:5060
    2) Also - The first line of that is a clickable link. "SIP Server/Call Manager" yet clicking on it does not produce any results.
