exception bad allocation
Discussion in '3CX Phone System - General' started by josvic, Mar 19, 2008.
  1. josvic
    Apr 24, 2007
    51
    I have installed the 5.1.4128 in my system, but I become in the log file unnumerous of exception bad allocation error, and the system goes inestable past a few hours of operation. I have then applied the new upgrade, but the exception bad allocation error persist... the only way to come all ok ist to restart the entire system.
    I have roolback to the 5.0.3790 and all seems to go OK, but to manage VoIP providers in queues or Digital Receptionist the don't transfer calls...
    Are someone with this same issue with the 5.1.4128 + upgrade?
    Regards...
