Exception when adding new extension
Discussion in '3CX Phone System - General' started by diamondra, Aug 25, 2017.
  1. diamondra
    Aug 11, 2017
    6
    hi ,i have this error when i try to add a new extension please someone can help me
    Internal Server Error(500)
    System.NullReferenceException: Object reference not set to an instance of an object.
    at ManagementConsoleJS.Helpers.ExtensionHelper.CreateExtension(String newDn, Tenant tenant, Group defaultGroup, DefaultGroupRight right)
    at ManagementConsoleJS.Helpers.ExtensionHelper.CreateExtension(String newDn, DefaultGroupRight right)
    at ManagementConsoleJS.Controllers.ExtensionListController.New()
    at Microsoft.AspNetCore.Mvc.Internal.ControllerActionInvoker.d__28.MoveNext()
    --- End of stack trace from previous location where exception was thrown ---
    at Microsoft.AspNetCore.Mvc.Internal.ControllerActionInvoker.d__18.MoveNext()
    at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task)
    at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)
    at Microsoft.AspNetCore.Builder.RouterMiddleware.d__4.MoveNext()
    at ManagementConsoleJS.Middleware.ExceptionWrapperMiddleware.d__3.MoveNext()
  2. IoannisM_3CX
    IoannisM_3CX Support Team
    Aug 10, 2017
    229
    18
    Hello @diamondra ,
    Try to add an extension using a different number e.g. if now you are using 001 try use 002. Does the problem still occurs?
    What are the specs of your system?
    Thank you
    diamondra likes this.
  3. diamondra
    Aug 11, 2017
    6
    i use netinst debian install on vmware esxi 6.5 ;these error appear when i click the button add
  4. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    6,444
    463
    Which version PBX are you running? Are you on the latest build? Did you use the Debian provided ISO or the 3CX provided one?
  5. diamondra
    Aug 11, 2017
    6
    i use elastix5 debian iso
    sorry for my engilsh
  6. YiannisH_3CX
    May 10, 2016
    6,444
    463
    Is this a fresh installation? Did you get any errors during the installation? Can you re-install in case something went wrong during the installation?
  7. diamondra
    Aug 11, 2017
    6
    i was had an licence_error.httpserror when i finish configuration 3cx but after reboot it was working .
    yes it's a fresh installation
  8. YiannisH_3CX
    May 10, 2016
    6,444
    463
    Please check your inbox as i have sent you a p.m
