Exchange 2010 UM, SIPNET & DTMF
Discussion in '3CX Phone System - General' started by anton7182, Nov 17, 2010.
  1. anton7182
    Nov 9, 2010
    Hello!
    My 3CX installation uses Exchange 2010 SP1 UM as a voicemail backend. When I call from "ouside" (I use SIPNET.RU provider) to access my voicemail, Exchange, for sure, wants my extension and PIN to be dialed.
    The problem is: SIPNET sends DTMF as "sip info". 3CX re-transmits those packets to the Exchanfe UM host, which seems to ignore them.
    Is there any way to transmit DTMF to Exchange UM host as a "rfc2833" packets?
    Thanks in advance,
    Anton
