Exchange 2010
Discussion in '3CX Phone System - General' started by setech, Jun 8, 2010.
  1. setech
    Jun 8, 2010
    Does anyone know how to change the default port on Exchange UM from 5060 to somthing else so i can install 3cx on the same box.
  2. StefanW
    Jun 2, 2009
    1,165
    74
    does not help, i have tried it.
    Exchange does not allow traffic from the same IP to the same IP.
    It clusters it as fraud and kills the call (you will see it in the windows event logs then).
    Even calling MS to disable this was no success to solve the issue.
  3. Ase
    Ase
    Jan 12, 2009
    58
    Hi Guys,
    Im looking for the solution to change Exchange 2010 SP1 SIP listening port.
    I found info from MS that If I want to change the SIP listening ports from 5060 & 5061 to something else i should make the changes in the msexchangeum.config file.
    I found the file but cannot find info on the commands (Keynames) I should put into it to receive my goal.
    Can You help me out?
    //Ase
  4. Ase
    Ase
    Jan 12, 2009
    58
    Urgent help needed, anyone?
    //Ase
  5. Strider
    Jun 24, 2010
    17
    I have tried allways, but no luck, when I asked Microsoft they informed me that UM could only use 5060, so I installed a seperate machine with Exchange and all good.
  6. Ase
    Ase
    Jan 12, 2009
    58
    Thanks for Your reply Strider,
    I think it is as bad as you say.
    It is typical MS to release this:
    http://technet.microsoft.com/en-us/library/aa998265.aspx
    saying:
    SIP (Microsoft Exchange Unified Messaging service)
    5060 (unsecured)
    5061 (secured)
    Ports can be changed in the Msexchangeum.config configuration file.
    Telling us it can be done, but no one (not even in the Technet forums can tell us how)...
    I am currious to hear from "StefanW " from 3CX that says he tested to run 3CX and Exchange 2010 on the same server.
    I cant even install 3CX on the same server because 3CX complaints that port 5060 is in use.
    //Ase
  7. abc123
    abc123 Active Member
    Nov 9, 2009
    712
    The solution is to change 3cx listening ports not exchange. You may also have to set up port forwarding from your sip providers on your firewall but not usually.
  8. Strider
    Jun 24, 2010
    17
    If you set the Exchange UM service to "manual", you will be able to install 3cx and then you can experiment.
  9. Ase
    Ase
    Jan 12, 2009
    58
    Hi Mark,
    Thanks for you input, A new way of seeing the problem.
    I tried it for 2-3 hours but could not get it to work yet.I will continue...
    //Ase
  10. Strider
    Jun 24, 2010
    17
    Sorry, forgot to add once service set to manual "stop" it, this will allow you to install, I have 3cx installed on 2K8 SBS and working fine.
