Exchange Calendar Status Synchronization
Discussion in '3CX Phone System - General' started by Calou, Jan 4, 2018.
  1. Calou
    Dec 15, 2017
    I have configured a exchange impersonated account in order to synchronise exchange calendar status but it doesn't work. How can i debug it? I see nothing in the 3cx logs.
    Thanks for help
  2. Charles_3CX
    Charles_3CX New Member
    3CX Support
    Jul 6, 2015
    114
    The log you require for this is the 3cxSystemService.log found under on the windows PBX machine under: C:\ProgramData\3CX\Instance1\Data\Logs..
    You must though first enable the verbose logging level from Activity Log > Settings within the management console and the restart services.
    To force sync restart the 3CX PhoneSystem 01 System Server service only. Check the log for errors in regards to exchnage sync.
    Also check the guides here:
    https://www.3cx.com/blog/docs/sync-ms-exchange-contacts/
    https://www.3cx.com/docs/how-to-create-impersonated-user/
    https://www.3cx.com/docs/manual/phonebook-directory/#h.t12u4qrbqsi
