Exchange SP1 UM
Discussion in '3CX Phone System - General' started by rico06, Mar 12, 2008.
  1. rico06
    rico06 New Member
    Jan 11, 2008
    143
    Hi, I need your help .
    I have one serveur with exchange server and 3CX. all registered of course
    I change the port SIP exchange to 5055 instead of 5060.
    The two services are avilable and start
    One the 3CX I install it with the local domaine name like azertty.qsdfgg.priv
    One the settig of 3CX exchange dialog box I put the same local domaine name azertty.qsdfgg.priv
    One the exchange bridge I use the IP local adress but same result with the local doamine name
    Result:
    With le local doamin name on the 3CX exchange dialog box
    22:29:28.125 Call::Terminate [CM503008]: Call(1): Call is terminated
    22:29:28.125 Call::RouteFailed [CM503014]: Call(1): Attempt to reach [sip:999@tamarinsdvlp.dyndns.org:5060] failed. Reason: Forbidden
    22:29:28.109 CallLeg::eek:nFailure [CM503003]: Call(1): Call to sip:MNU@svr-exchange07.tamarinsdvlp.priv:5055 has failed; Cause: 403 Forbidden; from IP:192.168.1.200:5065
    22:29:27.765 CallCtrl::eek:nSelectRouteReq [CM503004]: Call(1): Calling: DirSip:999@[Dev:sip:MSExchange@svr-exchange07.tamarinsdvlp.priv:5055;transport=TCP]
    22:29:27.703 CallCtrl::eek:nIncomingCall [CM503001]: Call(1): Incoming call from Ext.103 to [sip:999@tamarinsdvlp.dyndns.org:5060]
    With 127.0.0.1 on the 3CX exchange dialog box
    32:26.265 Call::Terminate [CM503008]: Call(1): Call is terminated
    22:32:26.265 Call::RouteFailed [CM503014]: Call(1): Attempt to reach [sip:999@tamarinsdvlp.dyndns.org:5060] failed. Reason: Forbidden
    22:32:26.265 CallLeg::eek:nFailure [CM503003]: Call(1): Call to sip:MNU@127.0.0.1:5055 has failed; Cause: 403 Forbidden; from IP:127.0.0.1:5065
    22:32:26.015 CallCtrl::eek:nSelectRouteReq [CM503004]: Call(1): Calling: DirSip:999@[Dev:sip:MSExchange@127.0.0.1:5055;transport=TCP]
    22:32:25.968 CallCtrl::eek:nIncomingCall [CM503001]: Call(1): Incoming call from Ext.103 to [sip:999@tamarinsdvlp.dyndns.org:5060]
    I have no idea of what to do !!! please help me
