Exclamation at phones
Discussion in '3CX Phone System - General' started by MartijnDoeland, Oct 12, 2018 at 10:51 AM.
  1. MartijnDoeland
    Nov 23, 2017
    47
    After the SP6 update I have annoying Exclamation marks at the extensions.
    Already disabled the setting in the Parameters but this doesn't do anything.
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    6,326
    448
    Hello @MartijnDoeland
    Please note that the warning is there as your extension passwords do not meet the minimum security requirements of the PBX. Once you update your passwords the warning will go away. You can automatically regenerate the passwords using the "Regenerate" button from the extensions tab but please keep in mind that that will reset all extension passwords including the voicemail pin .
    Also if you use the "Regenerate" button supported devices will re-provision automatically so will 3CX client. However legacy and non supported devices will have to be re-provisioned manually.
  3. MartijnDoeland
    Nov 23, 2017
    47
    Unfortunately I cannot regenerate every extension because strong usernames are denied by one of our external systems.
    The setting SHOWEXTWEAKPASS has no effect on the Exclamationmark.
  4. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,397
    273
    If your systems do not support Strong Usernames - then ignore the warning.
    SHOWEXTWEAKPASS is not even listen in my parameters. I think that was from v12 and perhaps not viable anymore.
  5. MartijnDoeland
    Nov 23, 2017
    47
    Funny, we started with v15. maybe it's because we're running on debian.
