Existence of FAX Server service?
Discussion in '3CX Phone System - General' started by Sopock, Jan 15, 2017.
Confirm service existence in SP4(v15)
  1. FAX server is present in MMC
    2 vote(s)
    100.0%
  2. No FAXSrv
    0 vote(s)
    0.0%
  1. Sopock
    Sopock Member
    Jul 11, 2012
    447
    20
    Hi!
    I've noticed there is no FAX service in management console? However, service is visible and started from Microsoft Management Console.
    Maybe updater should delete this service and file?
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    5,455
    354
    If you have upgraded to SP4 the service should be visible but not started. If you install with latest SP4 installer then the service should not be visible.
    Yes there is no dedicated fax service anymore in SP4
  3. bhedreen
    Nov 3, 2011
    Is there anyway we can uninstall SP4 then?
  4. Sopock
    Sopock Member
    Jul 11, 2012
    447
    20
    Sorry for confusion. Fax server is only merged to another service.
    Thanks. I see that startup type is still automatic on upgraded system.:confused:
  5. Wendelspanswick
    Jan 11, 2016
    63
    So on an updated system (SP4) does the Fax service need to stay as disabled under Microsoft services?
  6. YiannisH_3CX
    May 10, 2016
    5,455
    354
    Yes, the service will remain but it will be disabled
  7. Sopock
    Sopock Member
    Jul 11, 2012
    447
    20
    Maybe this "remnant" service should use another extension?
    Code:
    Error! Couldn't send registration for '888' extension.
  8. YiannisH_3CX
    May 10, 2016
    5,455
    354
    @Sopock
    Where do you get this error?
    Is your service still running after you upgraded to SP4?
  9. Sopock
    Sopock Member
    Jul 11, 2012
    447
    20
    Yes, I'm sure it will try to register on every (rare) reboot.
    I understand that FAXServer.log is not longer relevant, but it might useful for troubleshooting of any component if it can be started from admin command prompt. Global debug logging will also increase size of ManagementConsole.log without creating new file?
  10. YiannisH_3CX
    May 10, 2016
    5,455
    354
    You should disable the fax service if it is still running and set it to manual so it doesn't try to register. Also the fax server logs are included in the 3CXIVR.log. This will keep logs for as many days as you have it set in the logging service
