Exit from voicemail back to IVR
Discussion in '3CX Phone System - General' started by cmdias, Jun 28, 2017.
  1. cmdias
    Feb 13, 2017
    32
    Anyway in 3cx to exit from voicemail prompt when trying to reach an extension back to IVR ?
    10,868
    304
    The available options, once in a voice-mailbox are given to the caller. As far as I'm aware, they can't go back to the IVR.
  3. jbryant84
    jbryant84 New Member
    Apr 6, 2016
    109
    40
    Make a dummy (unregistered) extension that forwards to the IVR under forwarding rules, and make it the operator extension. When users record their voicemail prompt include the message "or press * to return to the main menu".
  4. leejor
    10,868
    304
    Unfortunately, the operator extension is the only "out" from voicemail. If you currently use it as an operator, you don't have this option.
