Expensive route warning tone
Discussion in 'Ideas' started by leejor, Oct 23, 2015.
  1. leejor
    Many PBXs have a "main" outgoing route, most likely VoIP trunks, with perhaps a backup, secondary route, in the event of first choice failure or congestion. Billing rates for the two groups may be very different especially on international calls. I suggest that there be an option (tick box) beside any second or third choice routes in outbound rules, that will add a double beep to notify the originator that the call is using the more expensive route.
