Expired maintenance is downsizing PRO license to 4SC !?
Discussion in '3CX Phone System - General' started by Edi Kojsi, Mar 12, 2018.
  1. Edi Kojsi
    Nov 28, 2017
    26
    What the following email from 3CX means:
    Your 3CX Maintenance will expire in 10 days.
    It's crucial you stay up to date with active maintenance, so you can benefit from new and improved features, bug fixes and security updates. The newer versions are tested with the latest operating systems and IP phone firmware.
    We are constantly improving 3CX, and we release a new version every year as well as several updates each year. With active maintenance you have access to new versions and any updates that may be released. So why not renew your 3CX Maintenance now? It's easy and saves you money.
    Purchasing 3CX Maintenance renewal is easy just go to https://customer.3cx.com/orderform/support.aspx.
    Use a credit card or your PayPal account - it only takes a few minutes.
    3CX Maintenance pricing is available here.
    When renewing your 3CX Maintenance, please have the following information available:
    Customer : xxx
    License Key: xxx
    Purchased: xxx
    Expiry: xxx
    You only have 10 days until your 3CX Maintenance expires, so we suggest you do this at your earliest convenience.
    Important: If 3CX manages your FQDN and security certificates for you, valid maintenance is required for us to continue to do so. When Maintenance or the key expires, the FQDN's and certificates will stop working. The FQDN's and certificates will be deleted 7 days after the expiry date. If you miss to renew your maintenance or key in time, you will need to perform a backup of your settings and reinstall 3CX.
    You have 90 days after the date of expiry to renew. If you fail to renew after the 90 day grace period, your PBX will be downsized to a 4SC Annual licence key.
    If you have any questions, please contact us.
    Does this means 3CX is punishing customers, if they don't renew their maintenance ?
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    6,016
    421
    Hello @Edi Kojsi
    Assuming you are running an Annual licence then yes, once your maintenance expires your key will be converted to a 4SC standard but with maintenance. The alternative of not renewing your annual licence is to have your licence deactivated completely.
  3. Edi Kojsi
    Nov 28, 2017
    26
    No, the license is perpetual pro 32SC.
    The customer at this point is not willing to renew maintenance.
  4. YiannisH_3CX
    May 10, 2016
    6,016
    421
    In order for us to check internally why you got this email for a perpetual license i will need to you send a p.m. with a screenshot of the email you received along with the license key.
    What happens with perpetual licenses is that once the grace period expires (90 days) you will still have a Pro key with the simultaneous calls un-affected but you will no longer have the ability to upgrade to a newer version. If at some point you decide that you want to upgrade to a newer version after the grace period expires then you will need to convert your key to annual and you automatically get free maintenance for a year from the day the conversion is made. The key will be converted to Annual with the same feature set and simultaneous calls you had on your perpetual key.
  5. Edi Kojsi
    Nov 28, 2017
    26
    Yiannis,
    I sent you a p.m. with license key.
