Explanation of CDR shortcodes.
Discussion in '3CX Phone System - General' started by Luis Santos, Aug 31, 2017.
  1. Luis Santos
    Jul 17, 2017
    Comming accross the CDR there are various accronoums, knowing what these mean would be of high inportance.
    if i could have the definitions for Reason Terminated and reason changed it would already be extremely helpful.
    HistoryID – seems to be an event ID number which is fine
    Callid – unique call identification number which is fine
    Duration – the time between the start and end of a call which is fine.
    TimeStart – the time stamp when an even started
    TimeAnswered - not sure what this is as either blank or exactly the same as TimeStart
    TimeEnd – seems to be the time of termination of call.
    ReasonTerminate – assumption is a reason for why the call ended and gives the following options
    • Connected
    • Failed
    • Failed_cancelled
    • NoAnswerTimeout
    • NoRouteExists
    • Redirected
    • RouteBusy
    • RouteNotFound
    • TargetBusy
    • TargetNotFound
    • TerminatedbyDst
    • TerminatedByRule
    • TerminatedBySync
    Would need to understand what each of these means and what it tells us
    FromNo – fine
    ToNo – fine
    FromDN – fine
    ToDn – fine
    DialNo –fine
    ReasonChanged – list of 8 text options –
    • FailedBXferOfDst,
    • FailedBXferOfSrc,
    • Fwd_NoAnswer,
    • Fwd_OnBusy,
    • QFwdToDNA,
    • Redirected,
    • ReplacedDst,
    • ReplacedSrc
    FinalNumber – fine
    FinalDN – fine
    Chains – Seems t be the call path flow .. fine
    FromDispname, ToDispname, FinalDispname – names, numbers or phone groups (or blank)
    ToType – Text Options – Extension, IVR, LastValid, Line, Queue .. fine
    FinalType – larger range of text options .. fine
    Would need to understand each of these fields.
