Export button does not respect filter setup
Discussion in '3CX Phone System - General' started by uhpadmin, May 22, 2017.
  1. uhpadmin
    May 22, 2017
    I found a bug, where Export button (csv) on Call Log page is pulling data one day backwards than what you set up in filter.
    Example:
    Go to Call log page,
    Set up Filter used for: from 19/05/2017 to 19/05/2017, External to Any, Unanswered
    Then hit Export and check e-mail / reports section.
    Result:
    web screen shows data correctly, however generated CSV contains data from 18/05/2017 instead 19/05/2017.
    Can you please test and provide fix?
    Thank you.
