export CFD has Error
Discussion in 'Call Flow Designer' started by Mekaeil Andisheh, Apr 10, 2018.
  1. Mekaeil Andisheh
    Apr 8, 2018
    15
    @edossantos
    @YiannisH_3CX
    it is my CFD :
    we have a webservice and get result value , after that assign the result value to the variable and finally transfer to call with result value webservice,
    the result value Webservice = Extension Sales team
    [​IMG]
    when i want to build it and upload in account , these errors happened :
    [​IMG]
    #1 Mekaeil Andisheh, Apr 10, 2018
    maziyarvex likes this.
  2. Mekaeil Andisheh
    Apr 8, 2018
    15
    more details :
    webservice :
    [​IMG]
    assign to variable :
    [​IMG]
    transfer call :
    [​IMG]
  3. Mekaeil Andisheh
    Apr 8, 2018
    15
    I resolved my Errors :)
    all of the Error happened because of Double quotation in Webservice address.
    "Webservice Address"
  4. edossantos
    edossantos Support Team
    Jun 27, 2007
    1,150
    86
    Yes, the address is an expression. If you need to enter a constant string value, use the "Constant string" option from the Expression Editor, which will add the quotes and escape any character you need.
    Mekaeil Andisheh likes this.
  5. Mekaeil Andisheh
    Apr 8, 2018
    15
    Thank you @edossantos ,
    we got the value with web service like this : {"result":134}
    and i want to set only the value(134) into variable in CFD.
    how i can assign 134 to variable with Assign to variable component in CFD ?
    [​IMG]
    thanks
  6. Mekaeil Andisheh
    Apr 8, 2018
    15
    According to this Article ,
    our json data :
    Code:
    "result": 134
    my component :
    my C# Code :
    Code:
    using System;
    using System.Collections.Generic;
    using System.Linq;
    using System.Text.RegularExpressions;
    using Newtonsoft.Json;
    namespace Parser
        public class MyParser
            public string JsonParser(MyJson model)
                return model.result;
        public class MyJson
            public int result { get; set; }
    but it does not work and we don't have any return value.
    and after that i want to assign the returned value and transfer to call. but we don't have any return value.
  7. edossantos
    Jun 27, 2007
    1,150
    86
    You have different options here. If you always get such a simple JSON maybe you can just create a simple algorithm to parse the string by searching substrings...
    If you want to use the Newtonsoft library, that's OK, but you need to consider the different cases. Maybe you need other script first to check if you have that JSON or not...
  8. Mekaeil Andisheh
    Apr 8, 2018
    15
    @edossantos
    thanks for your answer.
    i have some question, please answer me , thanks.
    i have a some Code like this :
    Code:
    using System;
    using System.Linq;
    namespace CallerExtension
        public class ExtValue
            public string returnExt(string json)
                string str          = json.ToString();  //  {"result":134}
                string searchString = '{"result":';
                int startIndex      = str.IndexOf(searchString); // 10
                return str.Substring(startIndex, str.Length - 1);  //
        public class MyJson
    and i can't understand what is the Object type and how i fill it and Method name.
    before use the "Launch External Script" component i tested the response JSON and it is correctly worked but the "Launch External Script" doesn't work!
    can you tell me how i can write the code in Script component , and how i can fill this component and how i can send json data to this script in component ?
    i couldn't find any document about External Script Component in CFD.
  9. edossantos
    Jun 27, 2007
    1,150
    86
  10. Mekaeil Andisheh
    Apr 8, 2018
    15
    Thank you so much @edossantos. :)
    i solved the problem.
    this is final code, i like to share my code maybe it is useful for someone :
    Code:
    using System;
    using System.Linq;
        public class MyJson
            public int returnExt(string json)
                var getJson = JsonConvert.DeserializeObject<MyJson>(json);
                return getJson.result;
    and this is the component :
