export extension from cli
Discussion in '3CX Phone System - General' started by 3CXusername, Aug 1, 2014.
  1. 3CXusername
    3CXusername New Member
    Jul 31, 2014
    183
    16
    Good Day,
    Is there anyway to export all extensions from cli? Basically the CLI version of GUI export extensions to CSV.
    thanks
  2. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    645
    Hi there,
    I did not understand what you want to achieve can you rephrase please and also clarify what version of 3CX are you running ?
  3. 3CXusername
    Jul 31, 2014
    183
    16
    Running v12 SP6
    CLI version of:
    If you need to export your extensions to a CSV file format to either save them as backup or to make a lot of changes to the users follow the next steps:
    Log in to the 3CX Management Console and click on the ‘Extensions’ node.
    Select the extensions that you want to export and click on the ‘Export extension button.
    Type in a file name and save the CSV file.
  4. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    645
    Yes that is correct it is the only way to export extension properties (but careful this will not include their forwarding rules).
    Alternatively if this helps you can do a full backup using 3CX Backup and Restore Tool and restore on another setup as a starting base.
