Export / import email templates
Discussion in 'Ideas' started by the60, Feb 23, 2017.
Tags:
  1. the60
    the60 New Member
    Oct 21, 2011
    117
    58
    Allow easy export & import of email templates.
    This would enable us to spend less time modifying each customer's 3CX email templates, and just use a set of templates that have been customized for our client's needs.
    Needless to say, the over-the-top 3CX advertising on the reports email drowns out the link to the report itself.
  2. the60
    the60 New Member
    Oct 21, 2011
    117
    58
    And what directory might this be? ;)
    (AFAIK, they are in the Postgress Database)
  3. voiptoys
    voiptoys Active Member
    Feb 13, 2013
    790
    134
    Be careful, directly accessing the PostgreSQL database can get your PBX flagged as unsupported and is strongly discouraged. The only supported way of accessing the PostgreSQL database is through the Call Control API. If you can't do it through the API, then you shouldn't do it at all.
