Export/Import extensions with more than one phone provisioned
Discussion in 'Ideas' started by VictorSP, Jan 5, 2018.
Export/Import extensions with more than one phone provisioned 5 5 3votes
5/5, 3 votes
  1. VictorSP
    Sep 6, 2016
    71
    13
    As 3cx Support team has confirmed us, now Export will only export the first phone provisioned to extension as Import is also only capable of importing 1 phone as well.
    Our customers need to export/import all the phones associated to an extension. I think it could be a great feature for following updates.
    Bye,
    Victor
  2. dkeethler
    Dec 30, 2015
    66
    19
    +1
    Need this.
