Export of PhoneLog
Discussion in '3CX Phone System - General' started by mrLunkwill, Aug 28, 2007.
  1. mrLunkwill
    Oct 15, 2006
    7
    Is there any way to export the phonelog if im not logged in?
    I have users that wants to have there phonerecord in a mail each week, and when i log in to the 3cx consol its no problem to export the log and attache it to a mail - but I need it to go smoother.
    What i want is to build a Consolapp that get tha log every monday morning (the timer and the app is no problem) but how do i get the log from 3cx - can i by sending loginparams to the log page (as well as the other params of the form) be able to get the log?
    Anybody has an ide of a solution?
  2. gbarnes
    Aug 3, 2007
    83
    call logs
    What I would do is copy the call_log.php file to mylog.php or something.
    In the scrip add
    $_SESSION['loggedin'] = time();
    Now feel free to poke around, ie generate the CSV file, using pre defined vars, set up at the top of script. I take it you know how to do this, its simple. (As you can write app I take it you can!)
    Now, monthly would be easy, so I would stick with that, but you could filter more than 7 days ago out if you wish.
    You will see the script generates a file (date.csv) or something, which can be sent via email, using some good freeware .php email scripts. I use one here.
    Now, when you wish to send the log, execute the script, or of course set up a weekly timer to execute every Monday.
    Might be a good idea to test it with your own email address first!
    Graeme
  3. mrLunkwill
    Oct 15, 2006
    7
    Case Closed :)
    Thanx gbarnes - for pointing me in the right direction
    For some reason I couldn’t get $_SESSION['loggedin'] = time(); to work I was just redirected to login screen. I placed it at the wrong place I guess –
    However I found another param that I used in the top of my new script
    $skip_session_check = true;
    So now my console app calls my new “mycall_log.php” and it work exactly as I want it to do
    Thanx again.
