Expression-NOW() (insert current date and time into database)(VAD)
Discussion in 'CRM / Helpdesk / App Integration' started by pondsenth, Mar 2, 2017.
  1. pondsenth
    Nov 4, 2016
    8
    #1 pondsenth, Mar 2, 2017
  2. pondsenth
    Nov 4, 2016
    8
      File size:
      29.6 KB
      6
  3. edossantos
    edossantos Support Team
    Jun 27, 2007
    1,677
    131
    Hi @pondsenth,
    You should use the SQL command to get the current date. For example in SQL server it's getDate (), but that depends on your SQL engine. That way the database engine determines the current date.
    Kind regards.
