Ext Group "Management"
Discussion in '3CX Phone System - General' started by megatech, Nov 9, 2009.
  1. megatech
    Oct 19, 2009
    14
    Does anyone know if this Ext Group "managment" can be renamed as it does not reflect our culture.
    Senior management are concerned that phone system administrators are being seen as business managers accross the enterprise.
    any help appreciated
    peter
    11,293
    361
    Well, whether the senior managers want to admit it or not, you are managing something, the phones. Did someone ask for a raise? I think that if there was a huge outcry over the use of the term "management" then 3CX would probably consider re-writing the program, however, this is the first time I've ever heard of a concern like this. I guess on the next release they could consider using the term "administrator", although that might upset a few people too.
  3. demonofsteel
    demonofsteel New Member
    Mar 28, 2008
    105
    IMHO Administrator is even higher that Manager.
    Anyways, I'm not sure it's worth doing the change, as we really are managers of our 3CX systems and not that many people are going to see that group anyway.
    If that confuses people anyway, just create another Extension Group called Business Managers, then people will stop complaining.
  4. megatech
    Oct 19, 2009
    14
    who cares why - just fix the software so it's not hard wired to someone else's idea of how a company should work (do all programmers have a control freak mentatlity where evertyhing needs to be done there - how hard can it be to change a label !!!!!!!).
    i would like to see the management group re-namable and also hidden
    I would also like to see group visibility in the assistant turned on an off per group/extension - we don't want some groups of people seeing who is and isn't making calls and to whom.
    we have executives on confidential calls being monitored by mail staff and casual staff
    3cx needs to grow up if they want to get serious in bigger business accounts and provide the customer with more configuration options - privacy is also now a much bigger issue in public companies and requires ability to shield call information to certain people/groups.
    the 3cx assistant configuratin file should be attached to the group the extension is in, therefore at the server level, within a group an administrator can set who has access to what data..
  5. pjr
    pjr New Member
    Oct 5, 2009
    154
    I raised the issue of visibilty of all groups within 3CX Assistant with 3CX and got the following reply:
    The feature they are referring to is the ability to only allow certain groups to see other groups.
