Ext Hardphone doesnt ring
Discussion in '3CX Phone System - General' started by rico06, Feb 18, 2008.
  1. rico06
    rico06 New Member
    Jan 11, 2008
    143
    I arrived to make call with my linksys at home but my last problem (for the moment) is to make it ring from the server to my home, this is what I get:
    CM503003]: Call(57): Call to sip:103@myhomedomaine.org has failed; Cause: 401 Unauthorized; from IP:xx.xxx.xxx.xxx:5060
    Any solution ??
    thanks
  2. Wardy
    Wardy New Member
    Sep 18, 2007
    110
    The only way I have managed to get this working is to use a VPN. other people in the forum seem to have had success but I had to use a VPN
    Stephen
  3. matthijsolislagers
    matthijsolislagers New Member
    140
    Please look under General Settings > Settings for Direct SIP Calls
    Check if local SIP domain is: myhomedomaine.org (or the domain u use in the linksys phone)
    That did the trick for me.
    You can also try to use a IP adress instead of a domain name.
