Ext is idle but considered as busy when dialed
Discussion in '3CX Phone System - General' started by chrischevy, Jun 21, 2010.
  1. chrischevy
    Jun 7, 2010
    74
    I have a problem with a snom370 phone. On the 3CX server (version 9 beta 2), the extension shows as Registered(idle). When I dial this extension, I am transfered to the voicemail. I can call any other extension without any problem. I restarted the services, rebooted the server, did a reset on the phone and I still have the same problem. I haven't tried to delete the extension, as I do not consider this as a solution.
    08:52:24.570 [CM503008]: Call(30): Call is terminated
    08:52:20.686 [CM503007]: Call(30): Device joined: sip:9999@127.0.0.1:40600;rinstance=ac6b60444e8070b4
    08:52:20.670 [CM503007]: Call(30): Device joined: sip:10001@10.0.0.67:5060;rinstance=2521db93a9a2712f
    08:52:20.670 [CM505001]: Ext.9999: Device info: Device Identified: [Man: 3CX Ltd.;Mod: Voice Mail Menu;Rev: General] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CX Voice Mail Menu] PBX contact: [sip:9999@127.0.0.1:5060]
    08:52:20.670 [CM503002]: Call(30): Alerting sip:9999@127.0.0.1:40600;rinstance=ac6b60444e8070b4
    08:52:20.498 [CM503025]: Call(30): Calling Ext:Ext.9999@[Dev:sip:9999@127.0.0.1:40600;rinstance=ac6b60444e8070b4]
    08:52:20.451 [CM503005]: Call(30): Forwarding: Ext:Ext.9999@[Dev:sip:9999@127.0.0.1:40600;rinstance=ac6b60444e8070b4]
    08:52:20.451 [CM503016]: Call(30): Attempt to reach <sip:1003@10.0.0.66:5060> failed. Reason: Busy
    08:52:20.451 [CM503014]: Call(30): No known route to target: <sip:1003@10.0.0.66:5060>
    08:52:20.451 [CM503010]: Making route(s) to <sip:1003@10.0.0.66:5060>
    08:52:20.451 [CM505004]: Bridge:[br01] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXPhoneSystem 9.0.12808.0] PBX contact: [sip:10001@10.0.0.66:5060]
    08:52:20.435 [CM503001]: Call(30): Incoming call from 1202@(Ln.10001@br01) to <sip:1003@10.0.0.66:5060>
    08:52:20.435 [CM503012]: Inbound out-of-office hours rule (unnamed) for 10001 forwards to DN:1000
    Can anyone help me with this issue ?
    Thank you
  2. carolinainnovative
    May 4, 2009
    369
    6
    Re: Extension is idle but considered as busy when dialed
    Could you set the PBX into verbose mode by going to the management console Settings > Advanced > verbose mode and restart 3CX services?
    Once you have done that, re-do the call and repost the logs, please post using code and /code tags.
    Thanks!
  3. chrischevy
    Jun 7, 2010
    74
    Here is the code in verbose mode:
    Code:
    09:55:34.834  Currently active calls [none]
    09:55:04.261  [CM503008]: Call(1): Call is terminated
    09:55:02.774  Currently active calls - 1: [1]
    09:54:57.593  Session 177 of leg C:1.1 is confirmed
    09:54:57.233  [CM503007]: Call(1): Device joined: sip:9999@127.0.0.1:40600;rinstance=a70b3350e90110fe
    09:54:57.233  [CM503007]: Call(1): Device joined: sip:10001@10.0.0.67:5060;rinstance=2521db93a9a2712f
    09:54:57.233  [MS210003] C:1.1:Answer provided. Connection(transcoding mode[unsecure]):10.0.0.66:7000(7001)
    09:54:57.233  [MS210001] C:1.2:Answer received. RTP connection[unsecure]: 127.0.0.1:40610(40611)
    09:54:57.233  Remote SDP is set for legC:1.2
    09:54:57.233  [CM505001]: Ext.9999: Device info: Device Identified: [Man: 3CX Ltd.;Mod: Voice Mail Menu;Rev: General] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CX Voice Mail Menu] PBX contact: [sip:9999@127.0.0.1:5060]
    09:54:57.233  [CM503002]: Call(1): Alerting sip:9999@127.0.0.1:40600;rinstance=a70b3350e90110fe
    09:54:57.045  [CM503025]: Call(1): Calling Ext:Ext.9999@[Dev:sip:9999@127.0.0.1:40600;rinstance=a70b3350e90110fe]
    09:54:57.045  [MS210002] C:1.2:Offer provided. Connection(transcoding mode): 127.0.0.1:7002(7003)
    09:54:56.998  [CM503005]: Call(1): Forwarding: Ext:Ext.9999@[Dev:sip:9999@127.0.0.1:40600;rinstance=a70b3350e90110fe]
    09:54:56.998  [CM503016]: Call(1): Attempt to reach <sip:1003@10.0.0.66:5060> failed. Reason: Busy
    09:54:56.998  [CM503014]: Call(1): No known route to target: <sip:1003@10.0.0.66:5060>
    09:54:56.998  [CM503010]: Making route(s) to <sip:1003@10.0.0.66:5060>
    09:54:56.998  [MS210000] C:1.1:Offer received. RTP connection: 10.0.0.67:7166(7167)
    09:54:56.998  Remote SDP is set for legC:1.1
    09:54:56.998  [CM505004]: Bridge:[br01] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXPhoneSystem 9.0.12808.0] PBX contact: [sip:10001@10.0.0.66:5060]
    09:54:56.998  [CM503001]: Call(1): Incoming call from 1202@(Ln.10001@br01) to <sip:1003@10.0.0.66:5060>
    09:54:56.889  [CM503012]: Inbound out-of-office hours rule (unnamed) for 10001 forwards to DN:1000
    09:54:56.857  Looking for inbound target: called=1003; caller=1202
    09:54:56.857  [CM500002]: Info on incoming INVITE:
      INVITE sip:1003@10.0.0.66:5060 SIP/2.0
      Via: SIP/2.0/UDP 10.0.0.67:5060;branch=z9hG4bK-d8754z-280e1252c46d5f57-1---d8754z-;rport=5060
      Max-Forwards: 70
      Contact: <sip:10001@10.0.0.67:5060>
      To: <sip:1003@10.0.0.66:5060>
      From: "xxxxxxxxx xxxxxxxxxxx"<sip:10001@10.0.0.66:5060>;tag=4a67da21
      Call-ID: ZWEwYzA0NDUxNWU2NDNiYjRkNDhiNmEyNjg5ZGNhNTM.
      CSeq: 2 INVITE
      Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REGISTER, SUBSCRIBE, NOTIFY, REFER, INFO, MESSAGE
      Proxy-Authorization: Digest username="10001",realm="3CXPhoneSystem",nonce="414d535c0230003048:079015e8d438470550558bd91108de26",uri="sip:1003@10.0.0.66:5060",response="6c60036ec58bbd505a2adc86e08b7010",algorithm=MD5
      Supported: replaces
      User-Agent: 3CXPhoneSystem 9.0.12808.0
      Content-Length: 0
      Remote-Party-ID: "Christian Chevrier"<sip:1202@svpbx02.brunet.local:5060>;party=calling
  4. chrischevy
    Jun 7, 2010
    74
    I couldn't wait any longer so I just deleted and re-created the extension.
    Thank you
  5. chrischevy
    Jun 7, 2010
    74
    The same problem came back on another extension.
    This is really anoying. I can't delete the extension this time.
    Anyone has found a fix for this ?
  6. KerryG
    KerryG Active Member
    Jun 19, 2009
    960
    turn off Do Not Disturb on the phone?
  7. chrischevy
    Jun 7, 2010
    74
    I finally deleted the extension again. I was afraid to loose the voicemail messages but it all stayed there.
  8. Eurylink
    Eurylink New Member
    May 25, 2008
    174
    Re: Ext is idle but considered as busy when dialed*Discussion
    I've same issue on a Snom 370 With 3CX v.9 final. I was thinking it was only my problem but now I think there is a problem in v.9. I try to delete extension and recreate but the problem permain randomly. The Snom firmware is 7.3.30. 3CX is installed on IIS.
  9. computer45
    Jun 29, 2010
    I too got the exact same problem with a series of grandstream devices.
    Might start from scratch.
