ext. to direct sip
Discussion in '3CX Phone System - General' started by DjCujo, Jun 27, 2007.
  1. DjCujo
    Jun 27, 2007
    6
    Hi there,
    U did a great job on this software !!
    I just can't figure out 2 things...
    1. When i make a direct sip call to (name)@voipbuster.com from my softphone it works great (i can see it in the logging). Now i made an extention with an forward to sip:(name)@voipbuster.com / (name)@voipbuster.com and both dit nog work :S in the logging it is trying to connect to number: (name@voipbuster.com). How can i create an "internal" extention number that will call the voipbuster account when i dail it ?
    2. I use voipbuster for outgoing calls, and i just can not get the caller id working :( When i register directly with my sip phone it works, but when i call with the phone wile it is registered to the 3cx i just can't get it to work :(
    It would be great if someone could help me with this,
    Sascha
  2. DjCujo
    Jun 27, 2007
    6
