ext
Discussion in 'Windows' started by pat71, Mar 18, 2016.
  1. pat71
    Mar 17, 2016
    44
    is there way to change presence using API, or even the status of the extension.
    any one did this please.
  2. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    645
  3. pat71
    Mar 17, 2016
    44
    Re: Changing extension to busy using API
    Thank you for the reply,
    I am trying to do that, but it just do not work. can you please give me sample code to make extension busy or not ring using code c#.
    Your help is much appreciate.
  4. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    645
    Hi there,
    Here's a c# sample I had ready which changes the current profile of an extension, thus the forwarding rules of the new profile will apply when dialing ext.
    Code:
    	//retrieve profiles list of ext
    	FwdProfile[] fps = ex.FwdProfiles;
    	// Available, Custom 1, CustomHours, Exceptions, Custom 2, Away, Out of office (random order)
    	//change profile
    	if (fps.Length > 0)
    		string newprofile = "";
    		switch (changeto)
    			case "avail": newprofile = "Available"; break;
    			case "away": newprofile = "Away"; break;
    			case "oof": newprofile = "Out of office"; break;
    			case "custom1": newprofile = "Custom 1"; break;
    			case "custom2": newprofile = "Custom 2"; break;
    		if (newprofile.Length > 0)
    			for (int i = 0; i < fps.Length; i++)
    				if (fps[i].Name == newprofile)
    					ex.CurrentProfile = fps[i];
    					ex.Save();
    					//reload to display last state
    					ex = ps.GetDNByNumber(extension.ToString()) as Extension;
    					break;
  5. pat71
    Mar 17, 2016
    44
    Thank you,
    I just need to understand this line please.
    break;
    why are we using ex = , can you explain.
    many thanks
  6. pat71
    Mar 17, 2016
    44
    Thanks it work like charm.
  7. pat71
    Mar 17, 2016
    44
    One more question?
    Can we change the status from Custom 1 to any message we like.
  8. NickD_3CX
    NickD_3CX Support Team
    Jun 2, 2014
    1,255
    63
    The name of the Custom 1 and 2 Profiles can actually be changed from within the Management Console -> Settings -> PBX (V14).
  9. pat71
    Mar 17, 2016
    44
    Thanks.
