Extension brief information
Discussion in '3CX Phone System - General' started by mixig, Feb 5, 2013.
  1. mixig
    mixig Active Member
    Dec 13, 2011
    530
    12
    one of the new feature in v11 SP3 is:
    When a new extension is created, details can now be copied to the clipboard.
    When I configured new extension (v11 with SP3 and v11 with SP4) and press Apply, there is a brief information, sip id, pass, pin... Also there is Proxy server / SIP server / registrar filed. In that filed there is no DEFAULT LOCAL IP (on all other places there is defualt local ip which was insert automatically by 3cx). In this case i get another ip which is on 3cx machine:
    Display name: John Doe
    Proxy server / SIP server / registrar: 10.x.x.x:5060
    Extension number / User ID: xxx
    Authentication ID: xxx
    Authentication Password: xxxxxxx
    DEFAULT LOCAL IP for example above is 192.168.x.x (v11 SP3)
    Second example is from v11 SP4
    Display name: asd
    Proxy server / SIP server / registrar: 89.x.x.x:5060
    DEFAULT LOCAL IP for example above is 10.x.x.x (v11 SP3)
    Is this a bug? Can it be done that in this box will be inserted DEFAULT LOCAL IP?? Because if someone is using the ip adress from this box it will not work at all...
