Extension Change Notification could be selective
Discussion in 'Ideas' started by vancouvercom, Apr 3, 2017.
Extension Change Notification could be selective 5 5 4votes
5/5, 4 votes
Should the Extensoin Change Notification be more Selectable (Less Global)?
  1. Yes
    100.0%
  2. No
    0 vote(s)
    0.0%
  3. Don't Care
    0 vote(s)
    0.0%
  1. vancouvercom
    Jun 12, 2013
    13
    I think it would be great to be able to Selectively include or exclude extensions that send notifications when the extension changes registration status. (Settings/Email/Notifications)
    Reasons:
    1) 3CX Phone Users are not always registered or connected and therefore constantly show notifications on Registration and De-Registration.
    2) System reboots send a huge number of extension notifications.
    3) System Extensions send notifications too and this is not needed or desirable.
    The Extension Notification of a Change is very useful, but it needs to be more selectable.
  2. techclarity
    techclarity New Member
    Nov 14, 2014
    109
    50
    Definitely need a way to at least exclude 3CX clients. We had to turn this notification off because of the volume of notifications we were getting from all our hosted clients. Would like to receive notifications though if a physical phone registration changes.
  3. Gavin Brett
    Dec 15, 2017
    This would be a great feature as when using 3CX client on Android - it is constantly sending emails that i am registered/unregistered when using 3G/4G - particularity when on long drives.
    Server/router/VPN restarts also cause a flood of emails.
    Regards
    Gavin
