Extension Custom Fields
Discussion in 'Ideas' started by sloweclair, Jul 15, 2017.
  1. sloweclair
    Jul 14, 2017
    I would love it if there was a way to have custom fields in the extensions. For example I want to change the label name. Right now you can really only do it via the First and Last name fields. What would be nice is we a custom field so we can use that in our provisioning file however we would like.
