Extension export/import needs to support all extension settings, not just old one from pre-v11 or so
Discussion in 'Ideas' started by brendan.helsham, May 11, 2016.
  1. brendan.helsham
    Jan 23, 2008
    37
    6
    - Extension export/import does not support some settings e.g. Remote STUN & Specific Time Zone settings for phone provisioning, and maybe others that I’ve not found. I think that whatever you can configure via the UI should be available via the Export and Import feature. For example, there’s not much point importing 100 extensions with phone provisioning information, and then have to go into each extension one at a time to update the time zone.
    o You should also be able to export the entire list of extensions, make changes to some fields and perform an update/import. Currently re-importing fails as the extension already exists.
    o Same should apply for inbound rules; why can’t you export/import to update in bulk?
  2. uptime1
    uptime1 New Member
    Jan 13, 2012
    112
    30
    Re: Extension export/import needs to support all extension settings, not just old one from pre-v11 or something like tha
    We rely on Extension export import extensively especially to create efficiency when deploying.
    +1
