Extension fields show incorrectly v14
Discussion in '3CX Phone System - General' started by jmd, Mar 14, 2016.
  1. jmd
    jmd
    Oct 5, 2015
    5
    When clicking on Extensions on the web interface, I have Last Name showing in the Extension field, Extension shows in the Last Name field, Email Address shows the MAC address, Mobile Number shows Phone Model, MAC Address shows email address.
    Within the extensions themselves, everything shows exactly where it should.
    The system has been restored from a v12.5 backup which may be causing an issue, but the same also applies if I create a brand new extension.
    Is there a way I can fix this?
    Have attached an example screenshot
  2. CentrexJ
    CentrexJ Member
    May 5, 2009
    458
    75
    Try with Chrome. I have a feeling you are looking at this with Edge browser.
  3. jmd
    jmd
    Oct 5, 2015
    5
    That was exactly the case. Always worth trying the simplest thing first.
    Thanks for your help.
