Extension.ForwardingRules always returns an empty list (Solved)
Discussion in 'CRM / Helpdesk / App Integration' started by R. Henriksen, Dec 19, 2016.
  1. R. Henriksen
    Dec 19, 2016
    The property Extension.ForwardingRules always returns an empty list.
    I have upgraded to v15 and when using the 3CX Configuration and Call Control API v2.0.0.0 (v15) the ForwardingRules property always returns an empty list.
    If I use the v1.6.0.0 (v14) API against the same installation the method returns a list of ForwardingRules as expected.
    I have also tried the DisplayAll OMSample with the same result.
    Any suggestions?
    Best regards
    apldoor likes this.
  2. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    645
    Hi R. Henriksen,
    Indeed I replicated this issue with the Call Control API sample and reported this to R&D.
    Thanks for the report, will get back to you when something new on this matter.
  3. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    645
    @R. Henriksen
    The correct way to list forwarding rules is the following:
    Current code:
    foreach (ExtensionRule er in e.ForwardingRules)
    System.Console.WriteLine("\t\t\t\t" + er);
    Replace with:
    extProfiles = e.FwdProfiles;
    foreach (FwdProfile extProfile in extProfiles)
    extRuleList = extProfile.ForwardingRules;
    foreach (ExtensionRule er in extRuleList)
    And on top of sample, below
    PhoneSystem ps = PhoneSystem.Root;
    add
    FwdProfile[] extProfiles;
    ExtensionRule[] extRuleList;
