Extension ID
Discussion in '3CX Phone System - General' started by petewatterschats, Feb 29, 2016.
  1. petewatterschats
    petewatterschats New Member
    Jan 19, 2016
    151
    My question is how to set the "Authinication ID"
    It says that "if the phone has a user ID Field enter the Extension Number"
    I given person will have a PC Windows Client, Smartphone client, Tablet client and VOIP Phone not connected to a PC.
    I assume they all will have the same extension, for the softclients from the emailed provisioning file.
    So what should I put in the Authinication ID the Extension Number
    10,375
    231
    In the case of 3CX, it will be the extension number. If you have multiple devices, all using the same extension number (SIP forking), then all credentials, on all devices, will be identical.
  3. petewatterschats
    Jan 19, 2016
    151
    When I created an extension in the begining I just took the default so the extension and ID are different
    I assume that I can go back into the extension and put the extension in for the ID but will need to re-provision the clients using that extension by sending an email with the file - go to the device click te file to re provision
    Is this what I should do
    Thanks for your help
  4. cfive
    cfive Member
    Aug 20, 2009
    284
    The default for both extension number and authentication id is what 3CX thinks it should be, based on what it suggests for "the next extension number".
    If you install with 3 digit extensions, the first might be 100. When you create your next, 3CX will then suggest 101 for extension number and authentication ID. If you decide, no, I don't want this extension to be 101, and change it to, say, 200, then unless you also change the authentication ID to 200, it will remain at 101.
    That's how they got out of sync, but even so, things will still work. It just gives a cleaner appearance to a human if they match ;-).
  5. cfive
    cfive Member
    Aug 20, 2009
    284
    p.s. yes, if you want to change anything you would reprovision.
